So my old 2.4 blew itself apart. Now that the new motor is in it won't start even though it's got a new battery and a new starter. The ecu has all the power going into it but nothing coming out. Bad ecu? Any way to fix it?
Do you get power to everything else? Could be a bad ground somewhere. Double check all your grounds and positive connections. One loose cable will prevent the jeep from starting
Slater's correct. I had trouble with my battery, I would leave my jeep off for 10-15 minutes in normal conditions, and the battery would be dead. Checked the terminals and had a loose connection on my ground. I tightened it and everything went back to normal.
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
