I was wondering if it was a good idea so i searched the forums but most links are out do you guys have any tip links or ideas i am pretty much a newb at this but i am learning as i go
While it would help to know more details about your particular jeep, the universal answer to your question will be to Google "Taurus Fan".
Flex-A-Lite; Wrangler II Electric Fan 475
StreetSide Price: $236.76
The Taurus fan I got from the junkyard was $12.99
The cube type relay for the low speed was $6.99.
Most say the low speed is sufficient for normal cooling.
I plan to hook this thing up with the low speed only, until I can afford the high speed relay & switch. Don't be tempted to use a Ford starter relay for the high speed. It isn't rated for continuous use.
Sorry my "Old Timers Disease" made me forget to post some links for you.:doh:
taurus fan swap - JeepForum.com
Delta Current Control
Now serving
JeepForum.com
Ford Taurus Two Speed E-Fan Install (pics) - JeepForum.com
Taurus Fan install - JeepForum.com
The stock fan studs need to be removed & short bolts put in their place.
Also there is some trimming of the Taurus fan's motor mounts, that needs to take place if you have the 4.2L.
