Picked up an electric fan today for my YJ came off an early 90's Lincoln Continental with the 3.8. Same part number as the Taurus. Can anyone give me some help on how to wire it... What size relay to run, fuse,wire, should I run to a switch? Any thoughts or suggestions would be appreciated thanks.
I used a write up by Mr. B on jeepforum.com. It was easy and I got it done in 3 hrs. I used 10 gauge wire, 50 amp relays(one hi, one low), a thermostat from o'reilly, a 50 amp circuit breaker at the positive side of the battery. I have a 4.0 so I had to cut the shroud to get it to mount right. It is a TIGHT squeeze. Apparently an XJ water pump solves that problem. Oh yeah, you're gonna need 5 bolts to but your water pump pulley on. It's all in the write up. Sorry I don't have a link but I'm at work, so I can't do too much right now.
