I was driving on the highway and was going to make a pass. I put the petal to the metal and then whaa, whaa, whaaaaaaaa. The electronic throttle control(ETC) light came on and I went idle and had to pull over. I pulled the key out and restarted it and it was fine. This has happened twice(both while accelerating) since I bought it(2011 2-door) back in Sept. I haven't had it looked at because both times after a restart I'm fine. Anyone else have a similar issue? If so anyone know exactly what may be happening?
Does the check engine light come on? TBW systems default to idle, or just slightly over it, anytime a fault is detected. A fault should be accompanied by a code and engine light. Sometimes a code set in a pending status and doesn't turn the light on unless the fault happens again within a certain time period. Take it somewhere and see if they can get a code out of it. It sounds like there is probably something going on in the pedal position sensor when you move the pedal quickly. This is what warranties are for, I suggest using yours. This stuff can get pricey and even if the dealer can't find something wrong now you will have it on record as a problem in case it causes you problems down the road.
Happened to me this weekend an hour and a half from home (2011 JKU). Flashing ETC light, rough idle, and no response when I stepped on the gas. We tried disconnecting the battery to reset, but it didn't work. Luckily, 24 roadside assistance got us on a flatbed to the nearest dealer who is (hopefully) looking at it today. Mine happened after I stalled the motor :redface: I could restart it, but nothing when I stepped on the gas.
Has happened a couple times here when i coast downhill. Do the key dance to read your code. Mine reads P2173 (high air flow/vaccum leak).
Just heard from the dealer and he said it's a bad power train control module and will be replaced under warranty. :thumb: Now I need to go learn how to do the key dance. :)
