1 - 1 of 1 Posts
Hello! Hoping to get a little direction here. Left turn lamp and marker are out-also not functional when headlights are on.
I'm getting 12V to both the marker and lamp-Also have continuity between the lamp and ground. Bulbs are fine, swapped them to the right side and they worked. Fuse doesn't matter, it's before the switch and the right turn signal / lamp are fine.
Any idea what else I should try?
1 - 1 of 1 Posts
