I put some PIAA lights on my new front bumper today and all went fine with routing the wiring and mounting the lights...but I am not sure where to tap in for the one wire that needs to be connected to a wire that only has power when the switch is on,
Where do you suggest?
I used a fuse tap on a unused switched fuse, it was M9.
Thanks Mac
I went ahead and did this today. Worked out fine.
I had to take a real close look at how you ran the wire on the inside of the fuse box to see that you had drilled a hole so the wire did not get pinched.
Easy fix but I hope this does not void the warranty in some way.
Thanks again...:thumb:
Thanks Mac
Glad it worked out, I should have mentioned the hole. I was thinking the same thing about the warrantee, lol, first hole I drilled in my Jeep. I was wondering if I should put a dab of silicone on the wire, but I doubt it will be any issue.
Here is a shot of the lights all hooked up! I live off the beaten path up in a wooded area and these lights lite up the pitch black stretch of road on my way home last night! They are awesome!
