Think I blow my a fuse, my radio went of( aftermarket radio ) and my aux lights don't work, I first I thought I blow my radio, but then I remember it draws it power for the cigarette light ( the power located to the left) so I test that and sure enough it was out, the power source on the right is working fine, still haven't open my fuse box it to late I'm tired and I don't have any tool with me never mind a tester.
I want to know if any one which fuse it could, so I can pick it up tomorrow.
P.S I doesn't say in the owners Manuel.
Are you pulling the full load of your aux lights off the cig lighter circuit?
Try one of these fuses...they are all 20 AMP:
M6
20 Amp Yellow
Power Outlet #1/Rain Sensor
M7
20 Amp Yellow
Power Outlet #2 (BATT/ACC SELECT)
M10
20 Amp Yellow
Ignition Off Draw — Vehicle Entertainment System (IOD-VES), Satellite Digital Audio Receiver (SDARS), DVD, Hands Free Module (HFM), RADIO, Antenna (ANT), Universal Garage Door Opener (UGDO), Vanity Lamp (VANITY LP)
M6
20 Amp Yellow
M7
20 Amp Yellow
M10
20 Amp Yellow
Thank you
I didn't install the aux light, but look like the shop draw the power from the same fuse that's for the tip
