So about 2 months ago my jeep had the NO BUS code and it died. I cleaned all the connections and grounds, and that seemed to clear up the problem. It was driving fine ever since. No codes nothing. Well today I go out to start her up, and everything is normal when I put the key in, then I go to turn the key and click, EVERYTHING dies. No lights, no power anything, no radio, no turning of the motor. Just completely dead. So I go under the hood, and mess with the ecu connections, jiggle them around, disconnect the battery etc. Go back to start it, I push the key in and the dash lights come on. Try to turn the key and BAM everything is dead again. I have a test light, that I put on the battery and the light came on, but i dont have a voltmeter. Any ideas? Is it most likely the battery? Or probably some other electrical problem?
I'd narrow down the battery being the culprit first. Sounds like something is shorting out and freaking the ECU out or the ECU is crapping the bed?
Well, I got the battery tested, and it was fine. So its some sort of electrical issue elsewhere. One thing I noticed, was recently when I would start the jeep up, if I tried to turn the signal's or wipers on, the power to the stereo, wipers and blinkers would die, so I would have to turn the key forward a bit (while the jeep was running) and it would restore the power back to the accessories....any ideas with that?>
If you can fix it by wiggling the ignition switch, the contacts in the ignition switch are defective. Replace it.
For the totally "dead problem" - check the minus cable where it attaches to the engine - bolt loose? Crimp/weld bad? I think I've replaced 3 or 4 that looked fine, but were bad.
Will do the ignition. And by the minus cable, you mean the negative battery cable correct? I found that it attaches right near the oil filter, so I cleaned that contact because it was pretty dirty. Still no start. I think I am going to go over all my grounds tomorrow and clean the hell out of them. I think that may be the problem. Its pretty dirty under there.
For the no-start, no crank:
Often the crimp on the ends of the battery cables go bad - more often than you'd suspect.
Use a jumper cable from the batt (-) to the engine block. If it starts now, the cable is bad.
Try it on the (+) side too.
