Hi All,
I recently bought a 1998 wrangler TJ about 5 months ago.
I've had several problems with it, but one that stands out is that my airbag light flashes on and off randomly, my check engine light turns on and off (i need a valve job on it though), my speedometer will go from my current speed and then drop down to 0mph for 10 seconds at a time while i'm still driving. My RPM gauge will do the same thing as my speedometer.
Is this common? I'm wondering if this is something i have to take in to fix, or has anyone fixed it on their own? I have a friend who's a mechanic but i don't want to ask his help if it ends up being a larger job.
Thank you in advance for any input you are able to provide!
Probably a bad connection on the dash cluster. You can take it out and clean/bend the tabs for better connection or try pushing hard against the dash next time it happens to see if it resolves.
