Wrangler Forum banner
2016 JK Sport 2 door 6 speed with 10k miles.
I have a computer/electrical issue that happens intermittently. The speedo drops out (needle goes to zero, then back up to speed), there's a chime, the traction, ABS, and brake lights light on the dash and then go out. Sometimes the clock resets, too, but not sure if this is related.
These don't have any immediate effect on the vehicles performance that I can notice. If I turn off the ignition, everything clears out.
Any ideas/tips?
The battery terminals were not loose - I just checked.
furthermore, check that the connections to the battery are tight.. my jeep didnt start the other day and it was from a loose termination.. i was able to just pull the neg cable off by hand..
i took a pliers to it and its fine now.. also, i had the dash light up like too, im suspecting the loose connection.
