I have a 95 wrangler that I have no power to the dash instruments nothing works mostly worried about speedo are there any fuses or relays for that stuff I've had jeeps but this is a new project jeep for me
If nothing works I would suspect a ground issue. Not sure on the 95 model but there is a ground on the tub near the E brake assembly that may be loose, corroded or missing. I would try a jumper wire from a known good ground and attach it to the dash and see if that will cure it.
