If your jeep has the edisco, supplied-it's REALLY worthithow good is the electronic sway bar system? is it worth it?
Mechanical quick dis-connects are $20 to $100 bucks and you just unbolt the existing swaybar links and lock-pin the new ones in-maybe takes 2/3 minutes to release the swaybar !!Why is that jimbox?
Bill, you nasty man you...i weep for the future generations who will never know the simple pleasures of manually disconnecting swaybars, manual hubs, etc.
"Oops, gotta throw it in 4wd, hope I have enough room to back up!!" :rofl:
Beats going out in the snow to manually dis-connect the sway bar !!, buthow does it even work for disconnecting and re-connecting?
hmm sounds coolThe edisco gearbox electrically seperates/rejoins the two piece sway bar--uses a male/female gear "slip-fit"-pretty strong, but sometimes is a little annoying trying to get level enough to RE-JOIN-
Not for the cost of a NEW setup !
:rofl::rofl: JIMBO
well, i'd only be taunting myself as well. :rofl:Bill, you nasty man you......you aren't taunting the non Rubi among us, are you? :zap:
