Engine problems
17667 Views 15 Replies 10 Participants Last post by  knox314
So winter hits and everytime I start the 2011 black ops jeep with 7500 miles on it, the lifters on drivers side are clacking away, So i change oil filters a few times and top it off hopeing its filter sensitive. Tried all the top brands with antidrainback valves, of course no fix so now its time to call the dealer and they get it on Thur.call me me Friday morning and yep its bad lifters the hole drivers side but itll be fixed by 4pm on sat., ok great. I recieve a call at 3 from dealer and they replaced all lifters and everything went perfect but after two cold starts its still making same noise and the're not sure what to do so they're gonna keep it and speak with Chrysler and dealership owner to find out what to do. So i knew when i bought this thing I was getting the same sheitty chrysler engine thats in every v6 pile of sheit chrysler/dodge minivan out their but come'on 6 bad lifters from the factory then obviously bad replacements or theirs something even worse wrong the engine. Not to mention its been in for two other issues prior to this, so whatever little faith I had in chrysler is pretty much running out quickly............................................
1 - 16 of 16 Posts
· Retired Moderator
Sorry.
I wonder if they only replaced the lifters and not other worn parts. Causing the good lifters to go bad again.
Kinda strange its making noise so quick after you fixed. Wonder if they even replaced them or just through some MMO in the crank and called it a day ??
Hope all turns out well
Hmm could be a oil galley plugged on that side of the motor I would be pissed and request a new short block.
· Super Moderator
Sorry.
Yep I learned that the hard day back in the 70's. Changed all the lifters in a 302 Mustang, and guess what? I still had the noise. Anytime I change lifters I change the cam now as a result of that lesson. Changing noisy/bad lifters w/o replacing the cam is asking for trouble.
:popcorn:
I would think this is the most likely cause. There have been incidents where Mexico assembled engine blocks weren't thoroughly cleaned which have caused problems. Take a look at your window sticker which will indicate where your engine and trans was assembled. Not 100%, but maybe an indicator.
3.8 is a good reliable engine with many going over 200000 miles. there have have been a few blown 08s and they do go through oil. if this was my jeep, i would wait to see what they are going to do to fix it. chrysler has replaced many of these engines under warranty. hang in there, it will be taken care of. also, as an after thought, are you running the right oil? sorry for your trouble, but hang in there.
· Super Moderator
+1
It could be one of the Mexican engines. Now that they replaced lifters and tossed a bunch of $$$ at it they might learn. When you change lifters change the cam. I hope the OP gets an engine out of the deal now.
Well as funny as the mexican motor crisis is thats now been started.... The latest on my jeep so far is a little frustrating, I recieved a call from the dealership mon. stating that the jeep made no noises for the shop foreman and everything was thought to be good but they wanted to keep it one more day because it was around 50degrees and they wanted to give it a true cold start first thing in the morning so ok cool, well then i hear nothing all day today, so i finally decide to call at 3 sure enough it made the same bad lifter noises as the day i brought it in so they are now speaking with chrysler about what the next steps to take are, they had already checked the other jeeps on the lot to confirm it was worse than the normal cold start noises from the factory per chryslers instruction and they started 8 of them 2 of which hadnt been started in over a week not a one they told me none of them made anything close to the same as what mine does so they relayed that to chrysler and where still waiting a reply when i had called so im in the dark now as to what the next chapter of stories will be from chrysler corp. and the dealership, any ideas as to what they will suggest???????? Or have to check/test next. by the way thanks for all the replies/suggestions/thoughts very informative as well as funny.......this forum and its members are one of the best ive been on....
Discussion Starter · #12 ·
So the latest and greatest from chryslers wonderfull world of engineers is they want the dealership to replace the pushrods?????????????????????????????????????????????? Because the mechanics definetily didnt check them when they replaced the lifters...................even they are annoyed with them.......just really starting to get pissed about this, i didnt pay almost $40000 for this jeep to be driving a rental for two weeks.
Best of luck, it doesnt seem rare or unusual to hear problems about the 3.8l in the wrangler. Not sure what chrysler did to this motor when they put it in our jeeps, because tradtionaly the 3.8 also found in caravans among others has been one of their most reliable power plants.
· Retired Moderator
How bout the cam?
1 - 16 of 16 Posts
