Anyone used Redline engine suppy on ebay for your rebuild kits? Need a re-ring kit for a 1996 4.0. There price is hard to beat @ $182
Wow, I used perfectengine it was $423. Came with
The engine kit was an Enginetech MKJ242A and contained the following components:
Enginetech P1593 Piston Set at .040" Oversize
Enginetech R38856 Piston Rings at .040" Oversize
Enginetech BB612J Rod Bearings at .010" Oversize
Enginetech BB468J Main Bearings at .010" Oversize
Enginetech CC480 Cam Bearings Victor Reinz 95-3232VR Engine Kit Gasket Set
Enginetech ES809 Camshaft Enginetech L2011 Lifters
Enginetech TS4160 Timing Kit Enginetech EP81A Oil Pump Enginetech PK256 Freeze Plug Set
Red Line should be good I think it's what 6=8 uses. but for that price it's just a re-ring kit.
I would never just do a re-ring kit all that labor just for rings if you have the engine apart why not replace all the bearings oil pump and pistons if out of spec.
I got the engine from a roll-over jeep to replace one that has 200,000 and some lower engine noise in my grandsons 95 wrangler. The engine is a 96 and has 82,000 miles and looks in good shape, but wanted to install new rings, bearings, oil pump, timing chain, etc while it's sitting in my shop waiting for the change over. All specs on the crank,cam, bore is great. Just looking at the re-ring kit.
im planning on buying the overhaul kit from redline. im rebuilding a 4.0 to swap in my jeep.recomended by several mech i know
