in my tj i have the 6 cylinder 4.0, is it feasable to run 37s??
B baga3636 · Registered Joined Jul 11, 2007 · 50 Posts Discussion Starter · #1 · Aug 13, 2007 Only show this user in my tj i have the 6 cylinder 4.0, is it feasable to run 37s??
George T. · Registered Joined Jun 26, 2007 · 547 Posts #2 · Aug 13, 2007 Only show this user i think it more axles and gears than engine size
B baga3636 · Registered Joined Jul 11, 2007 · 50 Posts Discussion Starter · #4 · Aug 13, 2007 Only show this user ya im re gearing and replacing axles,
foxinthemudd · Registered Joined Apr 26, 2007 · 2,704 Posts #5 · Aug 13, 2007 Only show this user don't think you should have a problem then
B baga3636 · Registered Joined Jul 11, 2007 · 50 Posts Discussion Starter · #6 · Aug 13, 2007 Only show this user i think ill be better off with just running 35s cuz it will be sort of a daily driver
foxinthemudd · Registered Joined Apr 26, 2007 · 2,704 Posts #7 · Aug 13, 2007 Only show this user seems a little more feasable. and 35's can pretty much go anywhere as it is.
