I recently bought a 95 YJ with a 2.5 L motor, and I can't stand how freaking slow it is, so I think I saved up enough money to get a new engine and drop it in. I am not really good around cars but I do have help from a few friends. I heard people drop Cherokee 6 cyl into YJ's, but not to sure I want to do that, like if it will even fit... Overall, if anyone could give me advice I will be very thankfull. I want a good enough motor to actually turn 35's and lift it. Also, is there any problems I may run into? such as cooling...ect.
Retired Moderator
No way. You'll come out way better to just go with another Jeep. You're looking at a huge job with tons of expense to make a serious changeoer like that.
Put 35's on and regear it. Gears can take the place of horsepower you dont need a big engine to turn over big tires. But if you are dead set on an engine swap it would cheaper to just find chevy 350 and swap it in instead of an I6.
Retired Moderator
you would definitely have room for it...my friend runs a V8 in his YJ...but i think he probably did some sheetmetal cutting
Discussion Starter · #7 · (Edited)
Well, I looked on cragslist and found a CJ with a cherokee engine and good 31's with a suspension, and only selling for 1200. I was thinking of buying that and stripping it, just for the tires I'd say thats a good deal. Should I still sell my jeep and buy another? Or does that deal sound reasonable enough?
*Also, would a 4 cyl transmission bolt onto a cherokee engine?
Retired Moderator
sounds pretty reasonable but it must have a lot of rust or somethin...but i guess if you wanted the tires and wheels and maybe some other parts then you could get it and swap the engine...but sellin the jeep and buyin another would be easier
