I have a 95 I6 w/5spd wrangler w/200,000 miles that has some lower end noise, mains i think or piston slap. Anyway i can buy a 96 I6 w/auto out of a grand ck w/86,000 miles for $250 w/out trans. Will this engine be a simple swap? Anything i will need or have to change? Thanks
Use your intake, and header. Plus the acressories from your motor and your good.
The engine looks very clean so i got it. After doing some more checking i see the block, head, crank all have different cast numbers than the 95. Does anyone know the difference? I read on one site the head has less flow than a 95. Also a rebuild kit is not the same for a 95. The 96 cost more than a 95.
