1 - 11 of 11 Posts
Currently my engine likes to whistle once I press the gas pedal about past halfway. The whistle does not occur when it idles. It is a 1989 4.2L engine with a weber 2 bbl carb on it. I have not done any inspection on it myself bc I have no idea where to start. Any thoughts?
Do you have some type of aftermarket intake? Or just a filter on top of the Carb.
Will hmmm check all your vacuum lines for a hole.
:rofl:Had a couple of young hotties whistle at me in traffic the other day!!!! They like my "cute" JEEP!!! and I thought it was me!!
Seriously with all that has been posted vacuum leak all the classic symptoms.
It doesn't seem to be a vaccine hose. I checked my hoses today. Couldn't find a leak. I think the engine is finally saying its good byes :-( I did a compression test and there is a 15psi difference from the no. 1 to the no. 6 cylinder.
15psi on an old motor isn't the end at least is starts easier with low compression. Maybe the miles are catching up might be time for an upgrade SBC sound s good got all winter to put one in.
1 - 11 of 11 Posts
