Anyone familiar with the European/Australian OEM 13.25 BBK? I cut and paste this from another forum (not sure if links to other forums is allowed here). Also the post is a little old and parts can be had cheaper.
European/Australian spec 13.25" factory brake rotors/calipers, for those looking for an OEM solution.
68040177AA - 13.25" Rotor 119.00 ea
68044865AA - Caliper Adaptor 37.10 ea
68044863AA - RH Caliper 63.45
68044862AA - LH Caliper 63.45
Total $439.10
A more "all inclusive" list of OEM parts from another site;
68044865AA ADAPTER, DISC BRAKE CALIPER $27.99 x2
68049018AA PIN KIT, DISC BRAKE $6.99 x2
68044862AA CALIPER ASSEMBLY RIGHT $70.99 x1
68044863AA CALIPER ASSEMBLY LEFT $70.99 x1
68044866AA (new) 68044866AC PAD KIT FRONT $152.99 x1
68040177AA 13" ROTOR FRONT BRAKE $85.99 x2
68045998AB Master Cylinder new# 68091278AB $101.99 x1
68045999AB BOOSTER, Power Brake $121.99 x1
Total $439.10
As I remember back to day was a tread on this forum for it. The problem all this parts is made for outside United State try to order it and you will see unless u made a trip to Europe or U have a close friend or family members live in Europe to order it for u.
Moparpartsgiant has them in stock. Quadratec stocks the rotors. I don’t see a problem getting them in the US. Only hiccup I found googling the parts numbers are the brake pads come up witheuropean websites. I bet with some more digging aftermarket brands can be found for brake pads that fit those calipers though
Anyone else familiar with this? I found out it’s also known as the BR6 brake upgrade. The rotors are available aftermarket, and cross referencing brake parts shows they use normal Jeep pads, which just leaves sourcing the calipers. Seems like a cost effective BBK
