Just installed these European / Australian Taillights on my '94 Wrangler, wanted to show them off and also see if anyone had an idea for a license plate light. Maybe a way to use the original clear lens cover from the factory taillights, as right now I have NO light on the tag.
Yep, I had to cut the Brake sending wire on the Brake pedal, and run a new line to the brake light on the European / Australian Taillights. I think it was worth it!!!
to be honest i am not fan of it. as long as it rocks your boat than you should not care about what others say. however. if you want just get those bolt on lights that are made for license plates. they will do the job...
cut an opening the bottom the same size as the stock fixture and use the clear plastic from the original.
