Did you change out the studs? The threads on exhaust bolts/studs get worn with heat. I have always replaced them with any gasket change. If the threads are worn in one spot you wont get a tight fit.
Really interested in the outcome of what you found. I have an exhaust leak in the same place and wanting to know if you had any tricks.
