I can feel an exhaust leak at the flange between exhaust manifold and the cat. I have a 4 cylinder 98 wrangler. In doing my research with the factory service manual I have determined that my exhaust system does not have a seal at this flange like the 6 cylinders do. I haven't opened it up yet to check but I am running off of that assumption. What should I do to repair the leak? Is there an aftermarket seal for the 4 cylinders? Or do I just replace the bolts? Is there a torque value for this? Any help would be greatly appreciated. Thanks!
Checked for crack by chance- u can be the seal at local autoparts stores- easy install- but inwiuld be new manifold to exhaust bolts...i brokenmine when i replaced header
I'm sorry I didn't understand that last part. And my question is can I put seal for 6 cyl on 4 cyl? 4 cyl doesn't have one so I'm just making sure. Thanks for response
