1 - 13 of 13 Posts
Yeah my jeep sounded like that, but way more extreme. I had an exhaust/intake leak and just replaced the gasket as well as a couple vacuum lines, it's good to go now. It's only been two days though, I'm going to re-torque the bolts on the manifold tmrw to make sure.
what noise, the ticking? All I can hear is ticking and background wind noise.
If yes; (ticking), that's your rocker arms. Nothing unusual. Maybe just have it running properly now after all that work and discovering a noise(s) that has always been there.
what noise, the ticking? All I can hear is ticking and background wind noise. If yes; (ticking), that's your rocker arms. Nothing unusual. Maybe just have it running properly now after all that work and discovering a noise(s) that has always been there.
but it's only under load, if I'm just cruising I don't hear anything or its very discreet.and I'm almost positive that it wasn't there before I replaced my exhaust manifold and loose lifter but all that's been replaced. Maybe a bad gasket? How do I know for sure?
If i were you, being that you say you just replaced a lifter, i would pull the valve cover and make sure all your rockers are torqued correctly and arent loose. Pain in the ass to have to go back in there, but the only way to know for sure
Other than a normal lifter noise, all I hear is the sound of the intake sucking in that little BS air non-cleaner, it will make a sound like that, a little rumble.
1 - 13 of 13 Posts
