I have a 2012 Unlimited Sport and recently put on the Magnaflow Offroad series Pro exhaust with a resonator. The clearance with the frame rail in the driver side is very tight and it has a tendency, when idling, to rattle against the frame.
Does any have suggestions as to how to adjust it to keep from hitting the frame?
Thank you!
I installed a dynomax high flow exhaust and had the same issue, but mine was vibrating at the skid plates. I added a few washers between the plate and the frame and it gave enough clearance to stop the vibration. Not sure where exactly yours is making contact so this may not be a possible solution for you.
Thanks for the feedback. I will look at this as a possible solution and post a response if it helps.
Thanks again.
