1 - 20 of 20 Posts
Trying to help a friend out with diagnosing what appears to be an exhaust rattle. We tighten the bolts from the exhaust pipe to the manifold as they were a little loose but the noise remains. It almost sounds like a loose heat shield, but we are not finding anything loose. Odd thing is that is is not constant. It seems to only occur under acceleration. It does not do it at idle or if you rev it up. Anyone got any ideas please?
2009 JKUS, auto
I had a bad baffle in my muffler that rattled at about 1000 RPM.
This appears to be coming from about under the front passenger side feet area.
Had a muffler rattle in my 94 2500 Chevy yrs ago, thought it was a exhaust pipe,
My 12 jk has a heat shield rattle on the cat, there's a bolt missing, but it only rattles at idle,
Didn't see a cracked manifold, but didn't look at it real close. I will take a look at that.
It is defiantly not engine pinging noise. It sounds like a thin piece of metal vibrating.
Hmmm with that kind of sound, probably not a manifold. Though they're pretty common for cracks. Not much on passenger side. Maybe try a rubber mallet with some taps to the cat. Maybe coming apart inside.
Check your exhaust by the crossmember. If you went wheeling and hit that stupid paper thin cross"bar" then thats your culprit. I hit that bar when my jeep was 3 days old and had to shim it with washers for clearence till i bought a proper skid. My buddy hit his so bad he had to grind some material off the bar..hope that helps
Cameron
do either of you have exhaust spacers?
I don't know much about the rancho exhaust but I have the spacers and even with red locktight it was able to back off and I got the same rattle but only taking off or with a low ish rpm and never just revving it had to have a load on it.
I had just got done reading all the TB on the 2012 manuals and the problems they had when this noise started. I have never been happier in my life to find a loose bolt lol
Discussion Starter · #15 ·
Well, it finally got bad enough that we were able to find it. It was a heat shield on the cross over pipe. It popped the tack welds. 5 min at the muffler shop and all fixed.
out of curiosity, is it this noise you hear (around 1 second mark on video)?
I am losing my mind trying to fix it. I've used zip ties, washers, and the noise always changes. I don't know 100% if it is the crossover but I'm almost hoping it is. I'm probably going to go somewhere and get it welded.
I'm hearing that noise when I accelerate in my 2010 jku at around 15-20 mph. Been making that noise for the year+ that I've owned it. I haven't tried anything yet. Started researching the problem a week ago, was going to try the worm gear hose clamps to on the heat shield of the exhaust (based on what I read somewhere in a forum).
I have three hose clamps, and washers and the noise persists. I'm hoping its not something else, so I'm going to try and get a few welds done on the heat shield and see if it fixes the issue.
The rattle in mine has been driving me crazy and I had no idea where to look until reading this thread. I just went out to the garage to look at the crossover bar and voila! The passenger side weld broke. When I shake it quickly, I hear that same rattle.
Debating on quick steel but likely will put some steel bans. Looking forward to finally being free of that rattle.
1 - 20 of 20 Posts
