1 - 15 of 15 Posts
Hello everyone, I just purchased a 1998 Jeep Wrangler TJ 4 cylinder. The current exhaust is rotted, and needs to be replaced. My thinking is putting a new exhaust system on, I would be taking out the cat and putting a straight pipe in Then getting an exhaust and tailpipe. Any suggestions on what to get?
Also, What size should the straight pipe be, and what size clamps should I get so I can secure it to the old pipe ? Thanks for the help.
Go to your local ma' and pop exhaust shop and theyll get you squared away a hell of a lot cheaper than buying online.
Keep the cat. TJs sound horrible straight piped.
Running any vehicle on public roads without a cat is illegal per federal regulations if it was originally built with one.
Running with a properly functioning cat should stop your exhaust from stinking (run without a top and/or doors and you'll find out).
Some posters state that running without a cat produces more power. I don't believe it.
A cat for my YJ is around $100.00 on Rock Auto.
A California CARB cat for OP's Jeep is $278.00 on Rock Auto.
Good Luck, L.M.
Reactions: jadmt
Okay I don’t want to get fined. I’ll keep the cat. But back to the original question.
What size should the pipe be (with the cat), and what size clamps should I get so I can secure it to the old pipe ? Thanks for the help.
Walker direct fit stuff is hard to beat...
Just order by application
Walker exhaust stuff is junk now, it used to be good but not any more, it'll rust out in a year. i run banks stainless monster exhaust. The xj my exhaust gets ripped off on the rocks all the time i just bend it back and put it back on. On the tj it stays as by design its tucked up a little better. it has surface rust but its solid. Its not very expensive.
I have walker exhaust on several vehicles and have no rust issues...
As for diameter... get under there and measure what fits wherever it is that you want a pipe...
1 - 15 of 15 Posts
