What did you all do for extending the gas line? Installed 1.25 inch body lift and haven't figured a way to make the gas cap work again
You dont need a longer fill line for a 1.25 bl. Unbolt the trim piece that the fill bolts to, start the screws, then bolt the trim back up and tighten the screws.wethington2011 said:What did you all do for extending the gas line? Installed 1.25 inch body lift and haven't figured a way to make the gas cap work again
