hey guys, some of yall may already know this, or may not be concerned with it. But if you are looking for or would just like to see your factory build sheet for your jeep heres what you do.
go to this website and input the requested info.
then in the comment box at the bottom, tell them you want your factory build sheet. I went ahead and gave my entire VIN in this box because earlier it only asked for part of it.
this is an example what you will receive back. took about an hour to get mine back.
Thank you for contacting the Jeep Customer Assistance Center regarding
your 1991 JEEP WRANGLER 4X4.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
VIN 2J4FY29S1********
Vehicle Description JEEP WRANGLER 4X4
Model Year 1991
Body Model YJ J L 77
Engine ERH- 4.0L I6 Power Tech Engine
Transmission DDQ- 5-Speed Manual Transmission
*P6 Premium Cloth Bucket Seats
ADC Convenience Group
AJGP Driver Confidence Group
ALA SE Decor Group
APAS Monotone Paint
BAPS 75 Amp Alternator
BCCS 430 Amp Maintenance Free Battery
BGAS Power Front Disc/Rear Drum Brakes
CADP High Back Bucket Seats
CDBP Reclining Front Seats
CFMP Rear Folding Seat
CKC Floor Carpet
CKNP Cargo Compartment Carpet
CUFP Full Length Floor Console
DBBC All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMMS 3.07 Rear Axle Ratio
DRJS 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GBBS Tinted Windshield Glass
GCCS Plastic Front Door Window
GCHS Half Metal Doors with Locks
GRVP Left Manual Mirror
GSVP Right Manual Mirror
GTVP Swing-Away Mirrors
HCDS Heater w/Instrument Pnl Ventilation
JCDS 100 MPH Primary Speedometer
JGBS Digital Clock
JHAP Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JKAP Locking Glove Box
LAPS Shift Indicator Warning Lamp
LBBP Courtesy Lamps
LDAP Underhood Lamp
LMAS Halogen Headlamps
MBAS Painted Front Bumper
MCFP Black Rear Bumper
MWBS Sport Bar w/Side Padding
NAAS Federal Emissions
NBKS EVAP Control System
NFSS 15 Gallon Fuel Tank
NMCS Heavy Duty Engine Cooling
PRD Prowler Red Clear Coat
QRDS Prowler Red Clear Coat
RAAC All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCBP 2 Speakers
SBA Power Rack and Pinion Steering
SCES Alcantara Wrap Steering Wheel
SFAS Standard Duty Shock Absorbers
SGAS Rear Shock Absorbers
TBBP Full Size Spare Tire
TBRS Outside Tire Carrier
TMW P215/75R15 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WJDP 15X7.0 Styled Steel Wheels
WLYC All Steel Wheels
YAAS Build To U.S. Mkt. Specifications
Our records indicate that the following recall campaign(s) have not been
performed by an authorized dealer:
Recall: B03
Description: PARK BRAKE PEDAL ASSEMBLY
Type: SAFETY
Date Issued: 09/27/2002
Status: Incomplete
Recall: 624
Description: FUEL TANK SENDING UNIT GASKET
Type: SAFETY
Date Issued: 02/06/1995
Status: INCOMPLETE
We suggest that you contact your local authorized dealer to make
arrangements for an inspection and, if necessary, corrective action at
no charge to you.
Please take a copy of this message with you at the time of service to
aid the process.
Although not required, it is recommended to bring a copy of the recall
notification with you to your dealer's service department when you bring
your vehicle in for this service.
Thanks again for your email.
Sincerely,
Alex
Customer Service Representative
