I just got a 1999 Jeep wrangler Sahara, the factory fog lights are still on it but do not work. I just got new bulbs for them both and only the driver side works... Wiring issue for passenger side?
Mostly old school..!
Both lights are fed by one light blue wire that runs in the harness down the driver's side inner fender, and the wire for the passenger side is spliced in about half way down that inner fender harness, so if your driver's side is working, then the issue is between that splice and the passenger side light or within the light fixture itself. Be sure and check for a good ground connection to that fixture also.
