1 - 11 of 11 Posts
I have a 2012 Sahara that came with the upgraded radio package. Infinity Speakers and sub, I also have SiriusXM Satellite Radio w/ 1-Yr Radio Subscription which ends in June. I am looking to replace the my factory 130 HU, with a Pioneer avh-2400bt and have a few questions
1. Since I already have satellite radio, will I be able to connect my new radio to the satellite antenna? and where is the antenna located?
2. The subscription is tied to a radio ID, when I install my new radio I will have to call Sirius Will they still honor the 1 yr free? since I changed the factory radio.
I really like the AVh-2400bt, main reason for upgrade is the option for a rearview camera, cannot see anything when reversing due to lift and rear tire.
i dont think it would be an issue transferring the account, i have no clue where the antenna wire is, so im no help for that part. i like the plug-n-play sirius unit, that way i can bring it inside and connect to my theater system and i have a portable sirius boom box.
Another reason for asking the quesiton is. I do not know if I need to buy the extra Sirius antenna that is needed to for and aftermarket radio which is almost $100, or If I can plug the one I already have into an aftermarket radio such as the Pioneer avh-2400bt
It's a huge YMMV getting Sirius to transfer over the trial program. At first they'll say it's not transferrable. Then they claim the dealer will need to call them to authorize it.
I finally elevated the issue to a manager and they agreed to the transfer.
The factory antenna connector is combined GPS and Satelitte.
Davefr,
I assume you switch out your Head Unit, hence the need for a transfer. Were you able to plug the factory gps/satelitte connector into your new radio?
Where is it located. I thought it would be under the front passenger or driveside rocker panels, I just looked under the foam and it is not there
Davefr,
Yes, I switched from the stock RES radio to a 430N RHB Nav Radio. It was 100% plug and play.
I believe the combined Sirius/GPS antenna is located in the overhead roll bar unit. The connector is obviously just behind the radio unit.
Few answers...
If you go with the Pioneer unit, you need the radio tuner and the Bus interface module.
If you swap factory HU then you just plug and play.
You use the factory antenna and plug into the radio tuner, then the interface module then into the HU. The antenna is in the rollbar and the wire runs underneath the dash behind the glove box.
As far as subscriptions you need to talk with the dealer to try and have the contract swapped over to a new radio ID number. Hit or miss but more like miss on that part.
if you go like I did and get a lifetime subscription, you can swap HU ID numbers 3 times for a fee of $75 each time. I did that like 4 years ago and swapped to a new HU when I got the Jeep. I used all of my previous parts such as the tuner and interface from my previous HU.
Take a look at the HU on the Pioneer page to see what it needs. Depends on if you want Sirius or XM - that will drive the correct parts needed.
A bit more in depth answers for your questions...
1) The factory antenna probably will not work with the aftermarket system for XM signal; a new one is included with the Satellite tuners, so you would need to run a new one - the best place to put it on Wranglers is the underneath the padding on the soundbar. As Lynskey said, you will also need a satellite tuner (SCC1) and Pioneer translator (CD-SB10) to get Sirius radio, or the Pioneer XM module (GEX-P920XM) for XM radio with that unit. Either of these options will set you back 75-150 bucks depending on where you get it.
The AVH-P2400BT looks like it uses last year's method for getting satellite radio, so getting those parts may be hard to do without a bit of searching. I don't know how set you are on that particular unit, but I would suggest going with a different radio if you want to keep your SiriusXM - the new aftermarket radio's use a cheaper and simpler method for receiving satellite broadcasts. I would look into Kenwood's multi-media units if you haven't already; the DDX419 and and the DDX719 would be my choices for Non-Navigation touch-screen radio's. They both have Bluetooth, iPod control, back-up camera inputs, and will play DVD or video; the main difference is the screen size - the 719 has a much larger motorized screen. I also like Kenwood's over the Pioneer because of the 4 volt pre-outs - the Pioneer only has 2 volt pre-outs, meaning a smaller signal to noise ratio... the Kenwood will sound a bit better.
If you want to add satellite radio to either of the Kenwoods, you just need the SiriusXM SXV200 tuner, which retails for $70.
2) Getting the accounts transferred probably won't happen. The free trail is only for your original radio's hardware. As others have said, you might be able to convince someone somewhere to transfer it for you, but it's extremely unlikely, and most people will just tell you it isn't possible.
If you threaten to cancel the subscription siriusXm folds. They are losing more business than they care to admit. If you push the issue they'll do it, I actually got 6 months extended for free
x2 :thumb:
Discussion Starter #11
E-Boven,
Thanks for the info, I was looking at the Kenwood as an option, as I like having a turn knob and the 4 volt pre-outs. This really helps.
1 - 11 of 11 Posts
