My 2004 a/c fan speed only works in the full on position—no lower speed. I replaced the whole panel, same problem. Any ideas?
Dave Dillehay
Knows a couple things...
Not knowing what you mean by the 'entire panel', did you replace the resistor pack above the passenger-side kick panel that controls all of the lower speeds? Only the High fan speed doesn't run off the resistor pack.
Looks like this...
It is located up near the fan motor. If you see photos of a different type of resistor pack with a steel shield around it with coils inside, that's the older style which your '04 doesn't use.
