1 - 20 of 30 Posts
Started about 2 yrs ago. Found 92 and let the fun begin. I patched the frame back then. Both rear shackle areas were rotted. Then last fall found out front frame near steering box was shot. Wow was it bad. Through a patch at it and it made the winter. Now the throw out bearing is going. Gotta drop transmition. Frame is so bad not sure I could put the transmition support back on. Decided to find another frame. CL is wonderful. Found a Penn. Frame. Small amount of rust. Can deal with it. Will post pictures soon. Check out the old thread to see how I got here.
I tried to keep budget around $1300 we will see. Frame was $600. Came with motor and front and rear axles. Swapped the motor for repair work on Mr 4 wheeler. Gonna sell axles recoop some $. I have all new spring bushings, motor and tranny mounts, and new body mounts. Needed new fenders so I got flat fender kit from ccfabs.com. cant wait to weld them up. Gonna be fun. Oh yeah not to mention the clutch kit I bought. This is my driver. So hoping it wont be off the road long. Post pics. soon.
finally got some pics. not sure what order they are in. new frame with old jeep. lots of work. don't plan on taking too long. gotta have it done for summer. plated both sides by rear shackles. planned on doing that with any frame I got. just incase. got some welds done (not too bad.)
some more weld pics. and the frame with the motor pulled. now just get the front end out and we are golden. still haven't decided what I am gone seal the frame with. chassis saver or something else. may just rhino line it. any thoughts?
Been pretty busy lately. Almost got the frame ready. Decided to raptor line it. Still need to get my yj to a buddies house to start the tare down. He has a much bigger garage and way more tools. Hopefully get frames sprayed this weekend. We will see.
Discussion Starter · #11 ·
Glad I went with the raptor liner. came out nice. gonna try and work on installing the flat fenders this weekend. we will see. Busy weekend. I did get the fuel lines with new filter back in frame. This warm weather is killing me not being able to drive it. :pullinghair: Soon.
Discussion Starter · #13 ·
got the fenders done. they came out nice. pics. are a little backwords. but you get the idea. Plan is to take the jeep to my friends garage tomorrow can't wait. Start tearing her down now. try and take pics as I go. I decided to put the side sheet metal for fender on inside of tubes. thought to show off the tubes a little more. what do ya think. will get a pic of them painted. not gonna put them on yet no sense. just gonna take them back off. wait till the swap is done.
Looks pretty cool. I cant wait to start doing changes. Since this 94 is the first jeep I ever owned. Will see what I can come up with.
I would suggest coating the inside of the frame with cavity wax.
The only dilemma is you need the gun and wax.
At the shop I work at we use wurth stuff. Good but pricey.
A local paint/body supply store should be able to help you. May even be easier to ask a local body shop to wax it for you. Your doing all the protecting outside the frame might as well do the inside too.
Discussion Starter · #19 ·
Its endless on how you can custamize a jeep. And you got a nice one to start. Congrats. Hope to see some pics of yours on this forum. Glad to see ya got on. Enjoy your jeep. And welcome to the new lifestyle. Ha:happyyes:
Yeah been reading up on doing something about the inside. Saw one video were a guy was just spraying this green stuff in right out of a can with a long tube attached. Not sure what it was called.
Sounds like a type of cavity wax. Wurth wax is black. 3m's wax is white. I like wurth's gun better. The wand is long and flexible and sprays in a full 360 degrees. Unfortunately the yj frame doesn't have a lot of access holes so the longer the wand(tube) the better. 3m makes aerosol cans but it only has a wd40 type hose on it.
1 - 20 of 30 Posts
