I have a 2007 Jeep Wrangler X - i cannot find my MPG! I am very curious to know how much MPG i get. In my boyfriends Jeep, it is displayed in the dashboard but mind is older and doesn't show. Any ideas?
Fill up until the pump clicks itself off (don't top off). reset Trip to 0, drive until you need gas, fill until pump clicks off and don't top off. Then divide # of miles on "Trip" by # of gallons you just pumped and that will be accurate MPG.
In the before time, you had to actually use math to figure that out. It is a fairly easy math equation, number of miles driven divided by number of gallons used to drive said miles.
Not all Jeeps have the readout.
Google will figure it for you, just have to get the numbers as mentioned above
That is assuming the speedometer/odometer are accurate
Sent from my SAMSUNG-SM-N920A using Tapatalk
