x-2Look on the inside of the tub/body behind where the diamond plate is, more then likely that was installed to hide more rust. Especially since those are very common areas for rust on Jeeps. Also look over your frame and make sure there are no rusted thru areas.
What do you think est. time is for the fix? total cost? yea thats not too far. One of my friends who i play soccer with is from there.Looks decent. The steering box is a pita to change, but you got the jeep for a nice price.
I'm in Herkimer ny, so semi local
Im sorry i dont have any pictures from the inside the car but will most def. get some once i have a chance. The car is currently atis it surface rust or rusted through? got a pic?
Ill also check all other areas for rust and put up an update.Look on the inside of the tub/body behind where the diamond plate is, more then likely that was installed to hide more rust. Especially since those are very common areas for rust on Jeeps. Also look over your frame and make sure there are no rusted thru areas.
Ill keep that link bookmarked and the original owner said it needed to be changed because after going over 40mph the steering felt wobly! I dont know if its the steering box as he said, but after going through theThe steering box is simple to change. But before you do. Make sure the frame is not rusted by where the box mounts.
Before replacing you might want to adjust the backlash.
0501Or Steer05 Z Photo 7
Loosen the jamb nut and turn the allen bolt a 1/4 turn. Tighten the jamb nut making sure the allen bolt does not move.
Wonder why the PO said it needed to be changed ?
I will get more pictures of the interior and all the area so you can see in detailjeep looks great take more pics and we can help you more, take some of the interior of the engine compartment and the steering box plz
yes, it will mainly be my winter car for few days out of the week and summer time fun so im hoping its a good 1200$ investment!Who cares for 1200 you got a deal
if you only use it for snow and top off fun
the rust is no problem at all
my current yj is a rusty heep but it
never misses a beat
You will read about 2006 tj costing
big money but are nothing but trouble
DW in a YJ is not as common but you could def be on to something. I think he'd know it if it was DW.Hmm the steering felt wobbly? Anyone else thinking "death wobble"?
instead of steering box? i will have more time this weekend to test few things out and take it out on the road.all you may need is a sway bar bushing set Quadratec has them for $14.99
