Hey guys, I have an 87 yj and only two of the temp switches work, the hot/cold one and the hi/low one. In other words I can't turn off my vents or switch it to my feet, does anyone know how i this might be able to fix this? Also my lighter doesn't work and I'd like to fix that as well
It may be the cable that runs from the lever to the actual vent. When I bought my 94 it had the same issue but the PO supplied the cable. Took about 20 minutes to install and now it works properly.
Did you have to take your whole dash off and everything? Or were you able to get to it by just reaching around the unit?
