Wrangler Forum banner
2013 JKU SPORT; 2.5' lift; 35" tires; re-geared to 4.56 gears; daily driver w/occasional mild off roading.
I recently just re-geared to 4.56 gears and reflashed with the gear change and appears to be running great. My question is should I change the setting of the t.case high and low ratios? I'm assuming if I don't change it, it will default to the stock setting. If I should change the t.case settings, what should they be changed to?
TIA for the assistance.
No they will stay the same since you didn't change them. If you swapped T-cases for a rubi or atlas then yes you would have to.
