I have a JK 2011 Unlimited.
Right front directional not working, Flasher makes common ticking sound for a few flashes then ticks fast.
Right Rear Directional works
Installed new front bulb, did not resolve the issue.
I would appreciate ideas on how to troubleshoot the issue. I understand the flasher is soldered behind the dash. My thought is there is a wiring issue to the light or the housing.
Thanks
I would try the left front bulb in the right front socket since you know its good. If it works then you new bulb was also bad. Speaking from experience on that one.
Unhook connector, inspect for corrosion, bent pins etc. Reseat.
If the left good bulb still wont work then break out a multi meter.
Does the marker light work on the right?
Should be 3 contacts inside the plug. Turn, marker and ground.
