2014 JKU, 7000 miles. When I set the parking brake, the brake light on the dash flashes. I am used to it being solid in other vehicles.
When I release the brake it goes out. Everything seems to work as it should.
What does your brake light do when e-brake is set. Flash or solid? I glanced at the manual but didn't look too hard.
I assume it's normal since it's done it since new, just not what I'm used to.
My 14 is solid till I drive away with it on then it flashes and beeps
probably because you have a 6 speed. my auto stays solid until you put it in drive and then it flashes.
the computer has (i believe) no way of knowing if you are in gear or not, so it just reverts to flashing
My 6-Speed manual flashes. First vehicle I've owned that does that.
