Just be aware that flat flares aren't "real" clearance. Tires can rub into the flare all day with no issue. You'll still have the same amount of bump stop as if you kept stock flares because its the metal lip the flare mounts on you have to worry about.
I've never had a problem with rubbing, whether turning, going over a pothole, or hopping a curb. As a daily driver it's fine.
However, there is no way I'd ever take this off road without a lift and proper bump stops.
sorry what size tires are those
