1 - 1 of 1 Posts
This is an ad from craigslist. I was wondering what exactley is the seller talking about by having a floating tub?
* 1949 Willys Jeep CJ2a * GREAT Project Crawler lots of potential! - $4900 (VANCOUVER)
Date: 2012-10-10, 7:35PM PDT
[email protected] [Errors when replying to ads?]
NEEDS SMALL AMOUNT OF FABRICATION AND ASSEMBLY. IF YOU WANT TO KNOW HOW MUCH PLEASE JUST CALL AND MAKE AN APPOINTMENT TO LOOK!
Lots of goodies come with this project jeep. Call or txt ME with any other questions, please no scammers 36zero-5two4-one897. ** NO EMAILS **
THE RUN DOWN ON THE JEEP
REBUILT SMALL BLOCK CHEV 350
ADVANCED ADAPTERS HEADERS NEW
STAINLESS SUPERTRAP EXHAUST WITH BAFFLES NEW
EDELBROCK 600 CFM CARB NEW
K & N HIGH FLOW AIR FILTER NEW
ALUMINUM WATER PUMP NEW
ALUMINUM BILLET POWER STEERING PUMP NEW
SINGLE WIRE ALTERNATOR NEW
FLUID AMPH DAMPENER NEW
ALUMINUM RACE SPEC GAS TANK W/ ANTI BACKFLOW NECK NEW
ELECTRIC FAN WITH SHROUD AND THERMOSTAT NEW
PAINLESS WIRING HARNESS NEW
4 CORE ALUMINUM RADIATOR NEW
HEI HYFIRE MALLORY DISTRIBUTOR NEW (INCLUDES: MALLORY 6AL BOX AND MALLORY LED DISTRIBUTOR - used)
BRAKE MASTER CYLINDER NEW
CLUTCH MASTER CYLINDER AND SLAVE CYLINDER NEW
STAINLESS STEEL BRAKE LINES NEW
5 - 36" BUCKSHOTS
5 - 16.5 ALUMINUM RIMS NEW
2 - RCI 5 POINT HARNESSES IN THE BOX NEW
DUAL RS 9000 SHOCKS WITH REMOTE ( ALL AROUND ) NEW
GM CARBOX 4 SPEED
DANA MODEL 20 TRANSFER CASE
FULL WIDTH CORPORATE 14 BOLT REAR END
FULL WIDTH DANA 44 FRONT END
3 - CUSTOM UPHOLSTERED SEATS
ALL DASH GAUGES
MANY, MANY MISCELLANEOUS EXTRA PARTS AND PIECES
HEADLIGHT BEZELS, BLINKER LIGHTS, TAILLIGHT BEZELS ETC.
WHAT IT NEEDS: THE TUB FLOATS INDEPENDENTLY FROM THE CHASSIS. HAS THE MAJORITY OF PARTS TO FINISH BUT WILL NEED SOME SMALL FABRICATION AND A LOT OF WRENCHING.
Q: Do you have receipts for the work and or parts on the engine and and trans, etc.? What all was done to the motor for the reubuild? Do you know whaqt era the motor is from?
A: Yes, I have many many receipts, though not all as this was built 15 years ago. The engine is a fresh rebuild that has been run and seasoned. BLOCK cast #3970010 the run was 69-80, the HEAD cast #3998991 the run was 72-73 it is a 75cc chamber they came in 194s & 202s could be either or? This was built to be a good solid engine and to run cool, no big cam, just a solid runner with new everything. Whoever buys this can pull the pan before they take it to see the work.
Q: IS THE FRAME THE ORIGINAL 1949 JEEP?
A: No , it is a 3/4 bowed frame
1 - 1 of 1 Posts
