1 - 20 of 31 Posts
Hi All
Has anyone seen any flush mount round tail lights? I like the recessed look but I dont want the LED.Any links or suggestions would be appreciated.
Rudy
Retired Moderator
I love the flush mounted stock lights. Those are prety snazzy looking. So you cut the tub with a regular saw?
You can cut it with a variety of different tools. When guys do round LED's they usually use a hole saw to do it. You could use a cut off wheel, a dremmel tool, a plasma cutter (although that would be rather messy) etc...
Retired Moderator
I've been thinking of putting in some LED ones myself since my original YJ tail lights have seen better days. I figured if I gotta replace 'em,might as well do an upgrade. Not to mention, to upgrade is less expensive.
Anybody got any tips and pics?
Retired Moderator
I've found 'em for half that, but I don't know how good they would look or if they would be bright enough.
I'm guessin' they have to be DOT approved to be legal, not that I really care though.
please share the link :)
either way $52 is still real cheap. if you won't post the link up then send it to me in a PM. i don't think the LED's include a back up light though. i don't know how you would solve this. i've also heard something about license plate illumination (?)
Retired Moderator
My license plate doesn't have a light anyway...
I don't have a link. I found them locally at a local place that sells 'em. I have seen them for a lot less on Ebay from time to time too. I've been pricin 'em for a few months, but I really want to get a good idea of what they look like in action before I start cuttin' holes in the jeep.
Discussion Starter · #15 ·
Ive noticed a truck backing up this morning about 5 a.m. and he had a set of red and a set of white LED's they were very bright.I'm of to autozone soon to see what they have.
Rudy
Hacks off Parts while Lit
i put round LEDs on mine. i got em for ~$60 shipped on ebay. i can finds the store if anyone is interested. i did not use a hole saw becasue the doggone saw (not counting the center) was $40. :flipoff: that. so, i measured 13 times and then took a jigsaw to it . you had to come at a couple differnet angles but it wasnt bad at all. i used bullet connectors to connect the lights and drilled a self tapping screw inside for the ground. it was pretty easy, and they look 3000 times better than my old sun rotted busted stockers.
i can take a pic tommorrow if anyone wants to see them.
1 - 20 of 31 Posts
