1 - 9 of 9 Posts
Anyone know where I can get these foam parts that attach to the soft top itself that hide the screws and go across on the front part of top?
See pictures attached. Looks like I need to replace both sides and both foams top and bottom
You can try calling Bestop. I can’t recall if the sell those pieces.
Let the Jeepn Times Roll
These are the replacements now. I had the same problem. Worked perfectly
Omix-Ada 13510.71 Soft Top Foam Tape Seal Kit for 2010-2018 Jeep Wrangler JK https://www.amazon.com/dp/B07B96C69F/ref=cm_sw_r_cp_apa_i_bVGtDbKF0NG4Z
Sent from my moto g(6) using Tapatalk
I use this from NAPA and cut my own.
You will find many uses for this on a JK soft top/hard top/doors.
NAPA Truck Cap Tape, Part #: BK 7701763. 11 bucks for a 30 ft roll.
They also sell it in nitrile
Thanks I already ordered the other one on amazon but will pick this up also sounds like it’s good to have
Vendor
Give cus a call at 1-800-845-3567 and we will get some sent your way!
CassieAtBestop
CassieAtBestop
Thanks I already got the one I ordered from amazon
1 - 9 of 9 Posts
