Howdy folks
my fog lamps will not come on and the relay sounds like a timer with a clicking sound.
Relay is bad?
Thanks
Sean
Sblanck said:
Howdy folks
Relay is bad?
Thanks
Sean
That would be my guess. Should click once when you apply current. Should be easy and cheap to replace.
Sounds like the best thing to check first. Could try swapping it out with another one of the same amperage rating or higher to test it.
Its a 3-4 dollar part and I can tell its the issue, I will swap it out tomorrow.
Thanks
Sean
