Hi all, Probably a very stupid question but, I have a 2010 jku and am installing new fog light bulbs but for some reason when I try to push the bulb back in, the tabs just don't seem to lock and the bulb does not seem to be able to be pushed back in as far down as it was when I took them out (which is why I think they are not locking in place). Even when I try to put the stock ones back in, its the same thing. Just wondering if this has happened to any one else, and how to you manage to get the dumb things to stay in the tabs. Cheers!
I'm having the same problem!!!!
At first I thought it was the new bulbs, so I ordered a different brand... still the same problem
I know this was a post from a couple months ago - but I finally figured out that the channels that the O ring fit in on the new bulbs were to small.... so, basically the O ring needed a little more room to flatten out....
I took out my Dremel, made the groove a bit wider and it went in just fine then.
