Can I say splice together 55w KCs to the factory fog light wires and have them function with the factory switch?
No the wattage is to high. If they were led they would be fine. That's why I purchased led s to be able to use stock switch. I bought a set off Inspired Engineering that are plug n play. No splicing required. They attach an adapter to the back
Depends on the draw. Mine work but I have two sets of led's that draw less than the factory fogs.
Using a relay you can wire the foglights to get it's power straight from the battery. Use the factory fogfight power wire to throw the relay. That way anytime you use the factory switch it will turn on both set.
☞ Sent from here ☜
