can someone with stock Sahara fog lights take a few pictures of the fog lights following the wiring harness up to the power distribution center. also of your relays in there,
found some stock fog lights and i want to know if i have the wiring harness already installed, i have the part in the dash that plugs into the switch so i think i have the harness.
So, I don't have any pics tonight, but to get you started, I just repaired my tonight. 89YJ Sahara, by the way. First thing I would do is check to see if there is a relay mounted under the left headlight inside the engine compartment. If the relay is not there, then I would check to see if there is a relay plug from your harness coming out of the bundle right before it enters the left headlight compartment. That should give you an indication as to whether the harness is configured already.
I'll try to get some pics tomorrow.
