2010 JK Does anyone have a wire digram for the fog Multifunction switch or the pins in the switch? I need to test the switch for the fogs to determine if I have a bad switch.
It may be easier to test the fog light harnesses (behind the bulbs) for presence of voltage when the switch is in the "on" position- removing the plugs and using a test light or digital multimeter should tell you want you want to know pretty quickly.
