Here ya go:
2 3/4" x 3/4" x 1/16” x 12 1/2" Aluminum Square Tube
1 3/8” x 20 3/4" Aluminum Rod
1 1/8” x 12” x 19” Aluminum Diamond Plate
3 6-32 x 3/4" Oval Head Stainless Steel Machine Screws. (Rod to table bolts)
3 6-32 Nuts With Built in External Lock Washers
4 3/4" Square Black Plastic Tube Insert Plugs
Latch Parts:
2 1/4” x 2 1/2" Hex Bolt (cut off head and threads to make pin out of shank)
2 1” Split Rings (for pulls)
2 1/16” Cotter Pins (or spring clips)
1 1/4" I.D. x 1 1/2" Spring (cut in two – half for each latch pin)
2 1/4" brass flat washers (or other that fits bolt with very little play and that will fit inside square tube).
Hinge/Hold Open Parts:
2 3/8” I.D. x 3/4" O.D. x 1/4" Thick Nylon Bushing
3’ 1/16” Wire Cable
2 1/16” Crimp Cable Stops (Cable runs through hole in side of tube and stop is crimped on inside).
2 6-32 x 3/8” Oval Head Stainless Steel Machine Screws (Cable hold down).
2 6-32 Nuts With Built in External Lock Washers (Used on table end to clamp hold open cable).
Mounting Parts:
4 1/4" x 20 Nutserts
4 1/4" x 1 1/2" Black Philips Head Machine Screws
4 1/4" Black Flat Washers
Notes:
Aluminum rod and square tube was purchased at Home Depot. Aluminum diamond plate was left over from another project, but originally came from Blue Collar Supply. All other hardware came from Ace Hardware.
