Do you finish with a clear coat? Not a painter. Looking at doing this in a few weeks. :wavey:
Did you prep your grill before spraying the bedliner?Nope. No clear coat on mine. I put several light coats on and was done. I initially put plasti-dip on and it peeled a bit and then got some chips I'm assuming from road debris. So i stripped that and sprayed bedliner on. I'm very happy with it.
I have a few questions. Why did you plastidip the grill before spraying the bedliner? I bedlined my door step but had to sand the painted area before spraying the bedliner. Also, what bedliner did you use?I did mine a few months ago. Plasti-dip it first. Cleaned with rubbing alcohol to get any grease or film off. Used a can of plasti-dip then a can of bedliner. No clear coat. Use light coats, thicker coats take longer to dry and sometimes don't level out. Be sure to clean the tip of the can after every spray. It dries and clogs the nozzle if you don't and it comes out in globs.
i did the same process. The reason i did plastidip first was . For some reason i change my mind i can still peel it off .I did mine a few months ago. Plasti-dip it first. Cleaned with rubbing alcohol to get any grease or film off. Used a can of plasti-dip then a can of bedliner. No clear coat. Use light coats, thicker coats take longer to dry and sometimes don't level out. Be sure to clean the tip of the can after every spray. It dries and clogs the nozzle if you don't and it comes out in globs.
it be cheaper to do it yourself couple cans of rustoleam bedliner paint will cost you under $20 bucksI've been thinking bout doing the line x thing on my grill anyone know how much that runs about?
X2. Cost me about $130 plus $25 for a new weather strip.Line x will run you roughly 150.00.
Definitely looking forward to doing this mod. Thanks for the info.Same reason as above, I can peel it off. Also I wanted a more textured look and the bed liner had that. I used It looks better to me. I will say this, if you go off road be sure to clean it thoroughly afterwards. Mine absorbed some of the dirt but nothing a quick coat can't fix. The cans of plasti-dip run around $6 and the bed liner was $10 or so. Way cheaper than paying someone to do it. Also you have the satisfaction of knowing you did it yourself.
could you post some pics of your flares .like to see themThe thing that made me go with line X is the 100% UV protection. Which is the same reason I did my fenders, that Way my fenders will never get that chalky gray look that jeep fenders always get
my post on the first page of this thread has a link. It is right above one of your posts. The link is of my jeep projects, should be like 4 pages. The close ups of the fenders are after they were done and any pics after those that show the fenders. You just have to be sure when someone does them that the fully incapsulate them because line x doesn't stick to plastic very well however it does stick to itself.could you post some pics of your flares .like to see them
