I have a Ford 8.8 rear axle. This is a 31 spline axle with 3.55 gears and an open diff. It does have drum brakes on it. It has been stripped of all of the brackets for the original leaf spring suspension. First $100 buys it.
Pick up only
If you would like to see pics I can e-mail them to you
Still for sale Will take a reasonable offer.
2.5L>4.0L
Work for a TJ
This axle is bare and ready to be modified. Needs mounting brackets for springs and controll arms. Was going to install it but found a Dana 44 out of a TJ so it was a straight swap. This is a popular swap into TJs. You will need to have wheel spacers or wider after market wheels because the axle is 15/16" narrower than a standard TJ axle. Bolt pattern is the same. If you want to see pics just let me know.
Thanks
BV Jeep
